1 members (baldeagle),
23
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 26 Junior Member | | Junior Member Joined: Apr 2005 Posts: 26 | Hello, will this get us by and thanks
I have been looking at this one from Lowes.
Kobalt High Output for $547..Cast Iron Pump, 13.3 scfm@90 psi and 15.0 scfm @ 40 psi... 135 max psi..60 gal. tank..
Just me and my son kicking it trying to build something. Check it out and for you in the know what do you think? Next step up is almost a windshield for the project.
evilstepdad | | | | | | Anonymous Unregistered | | Anonymous Unregistered | That compressor may have the Kobalt name on it but it is a Campbell-Hausfield manufactured items. That is not bad in my opinion as I have a cast iron C-H which has not caused me any problems. There are times when I get ahead of it using a DA, line sander, air drill or when priming but nothing that I cannot live with. This unit should work fine for you but you may have to wait for it from time to time. I think that is a 110VAC machine so it should not require any additional wiring though I would suggest wiring a dedicated circuit breaker/outlet for it as it may trip a breaker and [censored] your wife off. That is something you do not want to do.
GO ASTROS! | | | | | Joined: Apr 2005 Posts: 26 Junior Member | | Junior Member Joined: Apr 2005 Posts: 26 | Hello,
Actually it is a 208-230 volt and needs to have a 16amp breaker, has a list of tools that is supposed to be able to handle and the one's you listed were on there. They have one that is about $100 cheaper but it won't hanlde about 5 or 6 tools this one will and those are some of them.
evilstepdad | | | | | | Anonymous Unregistered | | Anonymous Unregistered | If you can get a 220 recpt wired up then you will be set. That unit should give you all you need. Keep it full of fresh oil. I changed mine out regularly during the breakin period and now do it every 100 hours. | | | | | Joined: Apr 2005 Posts: 26 Junior Member | | Junior Member Joined: Apr 2005 Posts: 26 | Thanks for the info.
evilstepdad | | | | | Joined: Nov 2004 Posts: 61 Member | | Member Joined: Nov 2004 Posts: 61 | | | |
