1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | today while trying to drive to school my truck died, having had this problem in the past, I knew it was the old gremlin Vaporlock. my question is, this hasn't happened to me all summer while driving in 106 degree weather and today it's only 85. the only thing that has changed is my sending unit went bad last week and over the weekend I replaced it, and I got it from my local classic chevy store so it is identical to my old one (outwardly anyway). could this suddenly cause vaporlock somehow and what do I do to fix the situation? Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | speaking of my 1969 gmc, sorry
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Today was extremely humid here in central Oklahoma, that may have been the problem. Back in the day the easy fix for Vapor Lock was an electric fuel pump.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My experience with vapor lock over the years has been it's a sign of a weak fuel pump. It's likely just coincidence with the sending unit.
| | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | Back in the day the easy fix for Vapor Lock was an electric fuel pump. Or clothes pins on the fuel line often wrapped in aluminum foil! Ah the good old days. SimS | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | The only way clothes pins and aluminum foil would work is you had to wear a tin foil hat to go with them.
| | | | | Joined: Jan 2015 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 39 | Check all flexible lines and connections from tank to pump. An air leak in the suction line will cause vapor lock like symptoms. Replacing the fuel sender can cause older hoses to crack and leak.
Tim White
49 Chevy panel 91 Jeep YJ
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Replacing the fuel sender can cause older hoses to crack and leak. Would you mind explaining how that works? | | | | | Joined: Jan 2015 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 39 | I'm assuming that the sender is in the tank. Most senders are connected to the hard fuel lines eith flexible hose thei hose has to be removed from the old sender and connected to the new sender. The hose is flexed a lot during this procedure it can crack and break or loosen at the fuel line. Or people like me can forget to tighten the clamp at the sender . All of the above can cause a vacuum leak which will cause the fuel pump to pump air instead of fuel. Viola faux vapor lock. Or as previously stated vapor lock like symptoms. And of course the pump could have crapped out.
Tim White
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Huh? My sender has no hoses attached to it only wiring. I admit I don't have a '69 to look at but my '47, '48 and '53 don't have hoses attached to the sender.
| | | | | Joined: Jan 2015 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 39 | Most later senders are a part of the tank fuel pickup. All this is removed from the tank as an assembly. If sender is separated from pickup tube the tank would (probably) have to be removed to replace it. It is difficult to remove a gas tank or at least lower it without removing or jostling the flexible fuel line. All I'm trying to say is an air leak any where in the suction line will cause poor to none fuel delivery. The only reason I brought this up is when I have sudden onset problem the best place to look is at the last change or repair. Looking at hose connections after replacing a fuel sender seems a logical place to start. (Even for one as stupid as I)
Tim White
| | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | my tank is behind the seat and has no flexible hoses attached until the fuel pump, but I did get my situation fixed. the pump was on it's last leg and my fuel filter was plugged (I did check the pump before replacing it, it was putting out about half of what it should) So thank you all for your input and advice.
