6 members (49nut, ShopRag, Youngin' Tut 59, Bills Auto Works, TexasA&M48Truck, Napco Man), 140 guests, and 3 robots.
Topics128,127
Posts1,056,681
Members48,452
#112623 12/03/2003 11:25 PM
I have read that the 235 in the passenger car in 1956 was painted BLUE. Further, that the 235 Thriftmaster was painted GREEN. My 235 is coming out of the rebuild shop shortly, and will be detailed prior to going in the '56 3100 Stepside. Question is, what color green is used if this is in fact true? I had saw a photo of a '55 Stepside with the motor painted green, and the valve cover painted blue. Can anyone out there enlighten me on correct color scheme (photo's would definately be a plus). Thank you.
Green usually denotes a 261. Truck 235's are usually gray.
Paint & Body Shop moderator
Josiah--Thanks for the reply. What I had read was at www.danroy.com then click on "The Tailgate eTalk" then click on ""Tech Article-Engine Colors". It mentioned the 1955 Truck Thriftmaster as "Grey". On the 1956 (which my truck is) it stated the Thriftmaster 235 as "Green" and the Thriftmaster Special 235 (and I have NO IDEA what the Thriftmaster Special is) as "Grey". Understanding of course both of these last two mentioned '56 motor colors are marked with a ** to indicate an "ASSUMPTION BECAUSE IT IS A CARRY-OVER FROM A PREVIOUS YEAR". Should I then paint it GREY, or GREEN?? It's a bit confusing as I don't see a 235 from 1955 that states it was painted GREEN! Anyone out there have any ideas on this??
OKAY--problem solved. grin The 235 going into my '56 Stepside will be GREY. Believe this is correct and that's what I'm going with. Grey should real good with the truck going to it's original color of Jet Black. NOW, as to the COLOR of Grey, any ideas??? :confused:
Brian, Chevy Duty, Jim Carter, The Truck Shop and others sell this paint. It is suppose to withstand 1200 degrees.
"MONGO"
"MONGO"
Got mine from CD it seems to be holding up pretty good after about 1000 miles.
Here's what my 235 looked like right before going in the truck.
[img]http://www.chevygmcofkc.org/Gallery/data/3021/1DCP_1472s.jpg[/img]
Mongo
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
Appreciate the responses Cd53 & Mongo (and thanks for the photo, it was great! You don't have a photo of after installation in the truck, do you?) Will be detailing the 235 in a couple weeks, and now I feel sure the color will be right! Thanks again. grin
"MONGO"
"MONGO"
Here's a couple I think I posted here before, might not be quite what your shooting for as I went with a little chrome. I'm shooting for more of a Nostagia hot rod look instead of a restoration. Since these pictures I've added a split exhaust manifold and I'm in the proccess of building a progressive linkage for a 3X intake I'm gonna put on it.
[img]http://www.chevygmcofkc.org/Gallery/data/3021/1DCP_1487s.jpg[/img]
[img]http://www.chevygmcofkc.org/Gallery/data/3021/1DCP_1486s.jpg[/img]
After the first drive, with everything hooked up and my car aircleaner installed.
[img]http://www.chevygmcofkc.org/Gallery/data/3021/1DCP_1501s.jpg[/img]
The spots on the chrome are from the leaky radiator cap I had installed.
MONGO
Mongo's Garage
MONGO,
Thank you so much for the photo's. NICE looking 235 you got there! smile
54 3100 with 235
62 flatbed dump C60 with 261
WOW!!! That is one CLEAN motor! grin
Here is my 235 1953 engine.
My engine
cd53--Great looking motor! smile Thank you all for your replies. NOW, I know what MINE is going to look like!!!
