2 members (ronsway, Hotrod Lincoln), 126 guests, and 2 robots.
Topics128,079
Posts1,056,312
Members48,442
#1126110 09/25/2015 2:37 AM
1953 1-ton, do I need to get the truck on jackstands to support the weight for any reason? I was thinking not.
1953 GMC 1-Ton Pickup with 350 and 700R4
No.
Bill Burmeister
But it would sure help getting the pumpkin in and out of the
housing. Don't see how you could do it with the truck down
on the ground.
I made an angle plate to use with my floor jack and
transmission adapter, but....I'm an old dude and can
use all the help I can get.
http://www.pbase.com/dennygraham/image/121488062
dg
Denny G
Sandwich, IL
Finished it last weekend. For anyone else who does it in the future I did it myself with the truck on the ground, and used two jacks to install the new one. One jack to lift the new carrier into place and hold it, and the second to tweak it to line up the bolt holes. If I did it again I would install studs in the top two holes rather than bolts so you could just jack it up and push it on.
Tell ya what Chad, You must be one tough guy!
I recently did mine and built a makeshift adapter for my floor jack, not nearly as nice as the one Denny built, put studs in the top two holes, and still had a hell of a time getting it in there. would have been much easier if I would have had a helper to run the jack though. I'm an old guy too!
Les
on the ground.
dg
DG, you're not old, you are just less stupid.
Carl
I had no problems with it at all. Stupid is as stupid does.
7
7 Offline
I have a Canadian built 1300 and I know the ring gears are of a different dimension when trying to change to a lower ratio.
Does anyone know if the entire American carrier (pumpkin) would bolt up to my rear axle housing?
1950 Chevrolet 1300 - Canadian Built
This truck is now for sale (9/2016)
All Original
More pix in Bolt Bucket
For what it's worth, I also had mine on the ground. That's what nice about the one ton's. Plenty of room under there! The end results are great, Sweet had mine up to 77MPH with the original 216. last week.
~ Jim Schmidt, Bucks County, PA
1953 Chevrolet 3804 1-ton
In the DITY Gallery
Q
Q Offline
If you want more height for working and don't want to jack the truck up...run your back wheels up on ramps or blocks of wood. I normally jack the truck up...unless I have a hoist..
