6 members (GMCJammer51, Greg_H, NorCal52Suburban, Hush, Cosmo, 1 invisible), 70 guests, and 2 robots.
Topics128,073
Posts1,055,908
Members48,429
#1125786 09/23/2015 3:21 PM
I would like to get rid of the closed drive line on my 50 1/2 ton. Will a mid 60's/70's chev truck 4 speed bolt onto the existing 235 with torque tube 3 speed ? The plan is to use a 4 speed transmission and a Colorado 3.42 rear axle.
Thanks guys
"Will a mid 60's/70's chev truck 4 speed bolt onto the existing 235 with torque tube 3 speed ?"
It depends on the 4-speed.
I think that the open drive-shaft SM420 4-speed was made up to 1967.
Other people will post information for higher-geared 4-speed/5-speed transmissions that will/might bolt up to you clutch housing.
Riding in the Passing Lane
67 on back 4 speed will bolt up to the bell housing.
1972 Chevy c10 Cheyenne Super
Crusing in the Passing Lane
465 started in '68. There are not 'higher geared' 4 speeds(4th is direct)unless a T-5, or NP-540 series 5 speed, OD version.
