5 members (Steelonsteel, Hotrod Lincoln, 55shaker, ShopRag, 78buckshot), 100 guests, and 1 robot.
Topics128,035
Posts1,055,552
There is a round knob that can be turned on the lower right side of the distributor. What is it for and what does it do? Thanks.
V
V Offline
Sounds like the grease cup knob. If the cup is properly filled with grease, turning it in a turn every now and then will force grease into some cavities to keep the dist shaft lubed.
You can unscrew it to remove it to check to see if it has any grease in it. Be careful removing the cup as a small spring may follow it out.
Dave
Thanks Dave
Leo Offline
Moderator
Moderator
I better give mine a turn, haven't done it yet this year.
