| | | Forums66 Topics128,088 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 319 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 319 | Life got in the way and it's been months since I installed the wiring harness. Bed is now installed so it's time to hook up the brake & stop lights. Unfortunately I don't know where the connection is. Here's a pic of the harness, and I'm assuming I make my own connections at the rear with the bare ends of these wires. But where do the two front connectors go? http://i35.photobucket.com/albums/d...20Pickup/20150923_155534_zpscc4xsccq.jpg
A VW guy trying his hand at a '59 LB fs. Lots to learn, but it's about the journey.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | right under the driver is where the interconnections for tail/turn/brake lights are located - see pics hereBill | | | | | Joined: Feb 2014 Posts: 319 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 319 | Thank you for the reply, and the link. But there's a problem. I don't have any unused connectors for these two tail light harness to connect to. No empty connectors under the dash or in the engine compartment. I expected to find them, didn't, and turned here in hopes of figuring out what was going on.
I purchased a "complete wiring set" with an alternator conversion harness by American Autowire through Tuckers. The instructions weren't the best but I got it in and it all works, except for this one problem.
Thoughts, comments, or suggestions??
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | NOT under the dash and NOT under the hood .... under the floor, on the frame about below the driver seat .... look at the bottom of the page on that link, which shows frame .... note labels "existing wires", those are the ones you plug in there if the harness you got is as original, in the top pic the connectors on your wires are shown at far right - the provision is also there for proper hookup of turn signal wires, if you don't have that look at the pic as if those wires don't exist
Bill | | | | | Joined: Feb 2014 Posts: 319 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 319 | Thank you, thank you, thank you. Just crawled under there and found the two connectors right where they belong. I have no recollection of their being there, but like I said, I installed the harness months ago and life has been a bit crazy since then. Tomorrow's task: rear lighting install. Did I mention, "thank you"??
