6 members (Shade Baby, baldeagle, Gdads51, treegrower, tclederman, DannyW), 64 guests, and 8 robots.
Topics128,014
Posts1,055,328
Members48,419
#1125645 09/22/2015 11:33 PM
The lower gen. bracket(the one the motor mount bolt goes thru) does not reach to the rear of the gen. It was that way when i got the truck. Shouldnt the bracket fit between the Tabs(?) on the gen?
You've neglected to tell us what make, what year, what engine or
what modifications you've made to you vehicle.
Here is the generator and bracket on a stock 1950, 216 Chevy truck:
http://www.pbase.com/dennygraham/image/149240763
dg
Denny G
Sandwich, IL
Something that may be affecting your fit is there are long, 7" and short (easy to identify as no band) 6" styles, as Denny said more info will help.
Sorry guys it is a 56 ,235
Sorry guys,Its a 56,235
U
U Offline
No need for apologies, just tell everybody what truck you are working on each time so it is easier to help you out. Also, a '1956 235' helps the description; but that would be assuming nothing had ever been done to it modification-wise.
Is the generator secured? Bolted down at two points on the base (front/rear)? You can use a stack of washers as spacers on a long bolt to secure that tab at the rear of the generator.
Brad
Wrench Fetcher, PhD
thanks for the reply.I had an extra bracket,and welded a 1" length of pipe on it. Should work fine when installed.Thanks btw,i assume everyone knows what i am working on,and you know what happens when you ASSUME!!
