7 members (SWEET, Donf, rfs56trk, sron48, 78buckshot, Wickedbass, JW51),
60
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | The lower gen. bracket(the one the motor mount bolt goes thru) does not reach to the rear of the gen. It was that way when i got the truck. Shouldnt the bracket fit between the Tabs(?) on the gen? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You've neglected to tell us what make, what year, what engine or what modifications you've made to you vehicle. Here is the generator and bracket on a stock 1950, 216 Chevy truck: http://www.pbase.com/dennygraham/image/149240763dg
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Something that may be affecting your fit is there are long, 7" and short (easy to identify as no band) 6" styles, as Denny said more info will help. | | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | Sorry guys it is a 56 ,235 | | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | No need for apologies, just tell everybody what truck you are working on each time so it is easier to help you out. Also, a '1956 235' helps the description; but that would be assuming nothing had ever been done to it modification-wise.
Is the generator secured? Bolted down at two points on the base (front/rear)? You can use a stack of washers as spacers on a long bolt to secure that tab at the rear of the generator.
Brad Wrench Fetcher, PhD | | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | thanks for the reply.I had an extra bracket,and welded a 1" length of pipe on it. Should work fine when installed.Thanks btw,i assume everyone knows what i am working on,and you know what happens when you ASSUME!! | | |
