| | | Forums66 Topics128,094 Posts1,056,157 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 71 | Hi all. Have a 1968 C40 dump truck with 2 speed rear end that I am putting rear drums back on after replacing wheel cylinders. After some looking I haven't been successful at finding the wheel bearing torque procedure. I know the bearings have to be preloaded but not sure what to torque it to. Any input would be great as the truck needs to go on a road trip in 2 days. Thanks.
1st Gen. Dodge Cummins 4x4 OVRTRQD Buick GNX #276 "If it died... we can fix it" | "If your not outraged, you're not paying attention." | "Do you know a large group of baboons is called a Congress? That explains a lot." ~author unwn
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Not torqued but snug and then back off a little, same idea as a front hub/bearings. | | | | | Joined: Aug 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 71 | Nothing different than we all have been doing...just wanted to make sure. Well it's on its way right now to Oregon so everybody's happy. Thanks!
