4 members (BC59, 5cameo8, crenwelge, Paul_WNC), 128 guests, and 3 robots.
Topics128,088
Posts1,056,373
Members48,442
I thought I had an Apache 3800 but now I'm not so sure. There are no emblems and I've yet to find numbers as there are no longer tags...unless I'm not looking in all the right places?
My truck is a 1958, dually, 8-lug, and Custom Cab (best I can tell), with primary and relief springs in the rear with more leaves than an oak tree. What other info can I provide to help make the distinction?
1958 Chevy Apache 3800
did you look at the driver's side door pillar for a VIN plate? also check for GVW plate there too.
also, how long is the bed. is there a truck bed or a flatbed? how about tires, are they 7.00x20 or smaller? bigger? just some things for you to check, usually if you have most of these traits, it's more than likely a 1.5 ton or larger.
Indy wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
3B Offline
Hy TonofFun, according to my truck sales data book for 1959 "Apaches are series 31 to 38. Medium duty Vikings consist of Series 40, 50 and 60. Heavy-duty Spartans include Series 70,80,90 and 100. Series 50, 70 and 90 are Low Cab Forward models, sometimes abbreviated as "LCF" models." Hope that helps.
That's what I'm finding as well, but I have no way of distinguishing between a 3800 Apache or a Viking 40. I looked again and there are no more numbers or data plates. But, the overall length is around 212" and the tires are 8R19.5. I also counted the leaves in the rear end and I have 8 primary and 8 relief, but I do know that a few have been added.
Indy wink
I've checked those spots and more, unfortunately...nothing there. I included the length overall and some other specs that you asked for in the post above but I failed to mention that there is currently no bed whatsoever. I am going to put a flatbed on it.
The 8 lug wheels are the giveaway, it's a 3800 1 ton Apache. The Vikings either used a large 5 lug front/10 lug rear, or a larger 6 lug all around. They also have much wider front fenders than the 1/2 through 1 ton trucks. There should be a serial number plate spot welded to the drivers side door pillar, usually on a windshield frame part of the door opening. The number should also be stamped on the drivers side frame rail, near the steering box.
Bill Burmeister
Thank you very much everyone!
The front end sheetmetal of the 3800 is the same as the other light duty Apaches. The Vikings have larger fenders that flare out ahead of the doors.
