1 members (baldeagle),
26
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 21 Member | | Member Joined: Jun 2002 Posts: 21 | I need a paint code for Bombay Ivory. I prefer a code for PPG, Dupont or Valspar paint, as my local paint shop doesn't have it in their books. This is for my 60 apache, but should be the same for 55-60. Thanks. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | don't know how close this is to "actual", but using some good original paint chips and color matching I came up w/ DUPONT # B8173 which is 'pearl white' from [gasp] chrysler k. other color I used was sub for 'cardinal red' DUPONT # 5291 which is a later vette 'mille miglia red' cardinal red and bombay ivory  looks right to me! Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | apache/cheyenne,
I think these codes for Dupont are correct (these codes are for '55-'57 and they should be the same until '59 - most likely the same in '60):
DUCO: 246-72961 DULUX: 93-72961
Dupont DUCO Lacquer mixing machine formula 2059
I do not have PPG/Ditzler codes but you might want to to try to find the phone number for their paint library. If you find the phone number, would you please post it here? They have a great library and helpful people (it might even be on-line now, but I cannot find it). I called them 6 years ago and they were quite helpful - I lost the phone number.
Good luck, Tim | | | | | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | The original PPG code for 55-58 Bombay Ivory was 80753, I do not have a current code, but maybe that will help in your search. | | |
