| | | Forums66 Topics128,154 Posts1,056,863 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I've got one of those that works just fine, I know that's sort of unusual for a Harbor Freight air tool. I've tried using the one that a friend has and it just hissed at me, never could get it started. Maybe you should take it back for exchange and hope you get a good one, I've had to do that with most stuff I get from HF. I've got several of their brad nailers that work about 20% of the time, the other 80% of the time you're taking them apart to try to figure out why they're not not working or to un-jam them. Had the same problem with there air ratchets and pneumatic grease guns, neither of which would start or run when you pulled the trigger.
dg
Denny G Sandwich, IL
| | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Thanks Denny. Well...I'm 0 for 2 so far on these things..too bad they look useful...I have loads of air and 100 psi but no go on either.
I'm heading back to the US in the next little while, I'll return one then, the other is past the 90 day return policy. Too bad you can't try these at the store before you buy...at least I don't think you can.. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Bring your own air supply, good for a couple of tries. I've actually used a Portable Air Tank to drive an air tool, for a short, short while.
dg
| | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Chicago Pneumatic Air Saw P/N 7900 works very well. They are twice the quality of HF I would say. I have cut many mediums and never had a problem. The key is a quality blade for the material you are working with. Yes, a small air tank is great for jobs too far from your supply. Use this approach with my air brad nailer many times. The C-P is also made "off shore" but seems to be a better build.
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep, no doubt CP makes a better tool, for professional use. But for us poor soles on limited income we have to suffer thru the headaches created by the cheap offshore crap. $110 plus shipping from SC facility vs $17.99 plus tax., local pickup. dg
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | also, try some different blades, Lenox makes some good ones | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | If either of these would start, I would.
I hear ya Denny..110 US is about a gazillion canuck rubles right now. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I've heard from two Canadians that they have to wait to purchase stuff until the currency exchange is more equitable. Wonder what caused that?
I use my HF Body Saw, but only when I have to. There are other methods that usually work. For example using a thin cutting disc on the grinder then using the body saw to finish it up. I wouldnt even think about using the body saw to make long cuts. An actual Saws-All is something that could work. | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Wonder what caused that?
oil $$ | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | I've had good luck with my body saw... other than getting replacement blades for it.. I lube it before each use tho.
