| | | Forums66 Topics128,180 Posts1,057,153 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | I may have the answer for you, installing a SM420 trans without all the cost. I needed to replace my original 1942 235 engine it had a broken crank.I installed a 1962 235 engine with low miles got it running and installed. I also added a 1948-53 truck bell housing and SM420 trans behind it no more double clutching. I made a adapter plate to the bell housing to accept the clutch and brake peddle no need to have the piece with the three bolt holes from your old bell housing welded to the 1948-53 truck bell housing. Will post it as a Tech Tip at some point. If I say so myself it turned out great. Check out this posting in the Driveline Forum for more details. If anyone would like to add a SM420 trans to their truck call me for the details will be happy to help. 1-262-392-2989.
Marv.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Marv, Can you please provide a link to the thread you're referring to? | | | | | Joined: Nov 1995 Posts: 5,744 24601 | | 24601 Joined: Nov 1995 Posts: 5,744 | Yeah, Grigg -- Marvin, do you have pictures and a writeup for that? Or just the pictures and I could talk to you off line about the writeup. That *would* make a great tech tip.
Regards, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Grigg/John.... Just go back to Driveline and 11/28/14 and the old thread,I remembered it RIGHT Away. Regards, steve sr.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I think the point we were trying to make is if you want to reference another thread the best way is post the address or link to it. Then no wild goose chase necessary. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Grigg no harm/no foul,just did,nt know how to link it back to the orig. post???? steve sr. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | No problem, just copy from the address bar and paste it here | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | | | |
