6 members (Jims46, Otto Skorzeny, Maybellene, Hotrod Lincoln, Barney1951, Deegs53), 66 guests, and 5 robots.
Topics128,181
Posts1,057,152
Members48,464
I may have the answer for you, installing a SM420 trans without all the cost. I needed to replace my original 1942 235 engine it had a broken crank.I installed a 1962 235 engine with low miles got it running and installed. I also added a 1948-53 truck bell housing and SM420 trans behind it no more double clutching. I made a adapter plate to the bell housing to accept the clutch and brake peddle no need to have the piece with the three bolt holes from your old bell housing welded to the 1948-53 truck bell housing. Will post it as a Tech Tip at some point. If I say so myself it turned out great. Check out this posting in the Driveline Forum for more details. If anyone would like to add a SM420 trans to their truck call me for the details will be happy to help. 1-262-392-2989.
Marv.
Marv,
Can you please provide a link to the thread you're referring to?
24601
24601
Yeah, Grigg -- Marvin, do you have pictures and a writeup for that? Or just the pictures and I could talk to you off line about the writeup. That *would* make a great tech tip.
Regards,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Grigg/John....
Just go back to Driveline and 11/28/14 and the old thread,I remembered it RIGHT Away.
Regards,
steve sr.
I think the point we were trying to make is if you want to reference another thread the best way is post the address or link to it.
Then no wild goose chase necessary.
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg no harm/no foul,just did,nt know how to link it back to the orig. post????
steve sr.
No problem, just copy from the address bar and paste it here
