| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 50 | Looking for diagram for 1950 3100 speedometer, new cable install.It was OK for about seventy five miles.The mileage work find,speed stop working ,It chatter must be the gear.Can you get repair part's
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Bump.
If you have no luck finding parts try posting an ad in the parts wanted section of the forum.
A lot of the hot rod guys upgrade.
A speedometer shop would probably be expensive. | | | | | Joined: Apr 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 50 | thank for help looking at part i bet a clock maker could fix it using a bushing | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | It depends on what's broke. Does your needle return to 0 and stop, or goes past 0 ...example... | | |
