1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
#1124573 09/17/2015 1:01 AM
Hi,
I have just received some nice shiny new gauges and am looking for a bit of help.
The oil pressure sender unit, and the temp sender unit don't appear to fit anywhere on the engine. I haven't looked yet to see if the speedo sender fits! Has anybody fitted these before that can point me in the right direction?
I have a '51 3100 pickup with a 3.9l straight six.
Now the proud owner of a '51 Chevy 3100
U
U Offline
...heck, I'll try to help:
The oil pressure sender unit's sending apparatus (mech or electrical) should thread in to the bottom portion of the engine on the driver's side. Looking at the engine, with the fan on your left, and the cab on your right, the location of connection is about 25 cm from the rear of the engine, and 10 cm from the top of the oil pan. There is a "t" shaped fitting located there, usually. It should connect.
The temperature sending unit connects to the temperature sender threaded into the cylinder head. This is at the rear of the cylinder head, when viewed from the front at the fan. It may be shiny brass.
The speedometer cable connects to the transmission.
Brad
Wrench Fetcher, PhD
The temp sender is too big to fit in the same place as the old one, and the instructions say it should be mounted in the intake manifold?!
it sounds as though the instructions are for a V8 powered truck.
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
I thought as much!!
Hot water on a V8 use the intake(or the thermostat housing). Hot water on an inline 6 use the head. Adapting a bigger fitting into the head can be frustrating. I have removed the base fitting from the head(not a lot of fun) only to find it is still too small for some Temp senders. With no way to remove the fitting from the gauge capillary(nice big word for ya to think about) You may find it is time to get a replacement Gauge for the brand new one you have already. Not the most fun you can have.
Steve H
Can I not just get a new sender that is the right spec for the straight 6?
What year engine?
What ohm reading gauge?
What size threads in the head?
Can you link the gauge kit you purchased?
Pics?
I'll have a look tomorrow and try and work out what engine it is and get back to you.
Moderated by  ndkid275, Phak1
