0 members (),
86
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I am dissembling a 51 chev pickup transmission to take parts to a guy in Europe. I pushed the main shaft out from the rear and removed the U-joint support from the rear to remove the speedo worm gear, but I just don't remember how I removed the rear main shaft bearing on a 48-54 SM318. I really don't need to remove the bearing, but It baffles me that I can't get it out. Seems to me I made some kind of stupid tool 50 years ago.
I can still take T85 amd T89 Warners apart in the dark, but I never messed with 318s that much. If a BW tore up with my driving, I figured I couldn't even back a SM318 out the drive way.
There's got to be a trick to it. But all the guys around here that I would have asked years ago have passed on. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is a snap ring around it that floats in the housing. You need to spread that snap ring & slide the bearing out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I think its beginning to come back to me. I think I took a piece of flat and bent it kind of the curvature of the bearing and ground kind of a point on it and drove it into the hole. I'm messing with it at the house. If I had taken it to the shop and pressure washed it so I could see what I'm up against, it probably would have helped. But I think I get the picture now. Thanks. | | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | There was a special flat-tipped expanding snap ring plier designed for just that job. It had a parallel-jaw arrangement and spread the tips to about 2 inches wide when fully expanded. Jerry
