5 members (MRMEROTH11, Eisenholtz, TexasA&M48Truck, Wickedbass, Gdads51), 66 guests, and 2 robots.
Topics128,066
Posts1,055,874
Members48,428
#1124091 09/14/2015 3:50 AM
after getting my gmc running it started overheating severely and started pouring steam out of the radiator, what could be causing this ive checked my water pump and it seems to be alright and there seems to be no blockage in either the engine or the radiator
Red dot, center of chest ...
If you are certain that there's no obstruction in the block or head and the thermostat is opening correctly, then it's probably a blown head gasket.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Did you just now get it running? It sounds like you didn't purge all the air out of the head when you filled coolant.
what would be the correct procedure for purging the air from the head?,this may be the problem
Crusing in the Passing Lane
Like Paul said, make sure the thermostat is opening-put the unit in a pan of water on the stove and observe. 190 or 195 degrees F would be good.
First of all, the thermostat should have a small vent hole in it for air to escape. In addition to that, I usually apply about 5 lbs of air pressure to the cooling system. I then crack the temp sender and make sure coolant comes out. Loosening heater hoses to purge the air helps too. Steam does not mean hot water. It means no water somewhere.
Retarded timing, vacuum leaks, and lean fuel mixture all cause overheating as well. Try 10-14 degrees BTDC at idle for a base timing setting.
thank you for the help , filled it up and bled the air and it ran amazingly cool.
