2 members (VicZ, oldsteve),
123
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 112 | im repainting my 64 fleetside chevy i like the original color but i cant find one close to it in base coat clear coat can anyone help also need paint code for the faun grey color of interior thanks | | | | | Joined: Sep 2004 Posts: 122 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 122 | What exterior color is it? As far as the interior color, I spent a lot of time trying to find the code for mine. I gave up.
However, Jim Carter sells the exact color for your interior. It is part number PT215 and is an exact match. It sells for $49.75 per quart and they recommend you need two quarts. I used their interior paint for my truck and it turned out great.
Good luck with your project. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | fan - there\'s some chips here - and more here select Chevrolet and/or truck then year for each may not be just what ya need but might help - you need to get a paint chip of the color you want and go to the paint supplier and look thru their chip collection to find one close enuff to suit ya Bill | | |
