1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | i cant find any information pointing me towards the actual original color of the interior for my truck. its been primered by previous owner and cant really tell what the original color was. i called chey duty and they said the orginal color, which they have, was champagne. they described it as an off white/ cream color. doesnt sound right to me. any one can help me out here? | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | I think the CD interior paint is very accurate, most interiors, if original, have faded over the years due to sun and poor quality paint. If you look really hard at an original cab interior, in protected spots, you will find the color CD is selling. But it is a lot darker than you will expect. And expensive. But it is enamel, while other vendors sell lacquer. | | | | | Joined: Feb 2000 Posts: 39 Member | | Member Joined: Feb 2000 Posts: 39 | I recently sprayed the interior of my 52 GMC with the Chevy Duty interior paint. I would describe it more as a flat grey metal metallic, somewhere between cast iron and stainless steel with just a hint of bronze or brown shading. Actually, mushroom metallic (as I have heard it described) comes pretty close to a verbal description. Anyway, the color of the paint supplied by Chevy Duty did closely match original paint found in my interior. A word of caution though: the Chevy Duty paint is enamal that requires a hardener, which you must order from a seperate supplier (Sherwin Williams brand). I hope this helps some!
Michael Zaic Dahlonega, GA 52 GMC 150 48 GMC 300
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Which is why I consider enamel better than lacquer. I just used generic activator from my local FLAPS. | | | | | Joined: Jun 2003 Posts: 3 Junior Member | | Junior Member Joined: Jun 2003 Posts: 3 | Brian, Go over to the Engine & Driveline Forum. Look at the 53 on the Post My old 53 is almost New... New Old 53 has the Champagne paint from Chevy Duty on the interior of his truck. That is as close as I've seen | | | | | Joined: May 2003 Posts: 224 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 224 | excellant relpies guys, thanks alot. i was pretty sure that chevy duty would have a reliable paint color that was close to the original. i guess the lady i talked to just didnt really know how to describe it.
ill order from chevy duty then, hopfully all turns out alright. thanks again | | |
