7 members (Peggy M, mick53, cmayna, Lostbuthaulinass, RaNfLaS, Southerntruck, JW51), 181 guests, and 0 robots.
Topics128,114
Posts1,056,285
Members48,439
i cant find any information pointing me towards the actual original color of the interior for my truck. its been primered by previous owner and cant really tell what the original color was. i called chey duty and they said the orginal color, which they have, was champagne. they described it as an off white/ cream color. doesnt sound right to me. any one can help me out here?
I think the CD interior paint is very accurate, most interiors, if original, have faded over the years due to sun and poor quality paint. If you look really hard at an original cab interior, in protected spots, you will find the color CD is selling. But it is a lot darker than you will expect. And expensive. But it is enamel, while other vendors sell lacquer.
I recently sprayed the interior of my 52 GMC with the Chevy Duty interior paint. I would describe it more as a flat grey metal metallic, somewhere between cast iron and stainless steel with just a hint of bronze or brown shading. Actually, mushroom metallic (as I have heard it described) comes pretty close to a verbal description. Anyway, the color of the paint supplied by Chevy Duty did closely match original paint found in my interior. A word of caution though: the Chevy Duty paint is enamal that requires a hardener, which you must order from a seperate supplier (Sherwin Williams brand). wink
I hope this helps some!
Michael Zaic
Dahlonega, GA
52 GMC 150
48 GMC 300
Which is why I consider enamel better than lacquer. I just used generic activator from my local FLAPS.
Junior Member
Junior Member
Brian,
Go over to the Engine & Driveline Forum. Look at the 53 on the Post My old 53 is almost New... New Old 53 has the Champagne paint from Chevy Duty on the interior of his truck. That is as close as I've seen
excellant relpies guys, thanks alot. i was pretty sure that chevy duty would have a reliable paint color that was close to the original. i guess the lady i talked to just didnt really know how to describe it.
ill order from chevy duty then, hopfully all turns out alright. thanks again
