4 members (66flea, FAST55, 3100RustyParts, Bill Hanlon), 80 guests, and 2 robots.
Topics128,214
Posts1,057,488
Members48,473
After installing a new master cylinder / power booster my brakes worked great but will nearly lock up when when driving stop and go. My pedal is up and all 4 wheels are tight. I have to either readjust the push rod or wait for the pedal to go back to normal. Problem seems to be with the master cylinder. Disconnecting the vacuum doesn't help. This is an all drum application with no proportioning value needed. Perplexed.
It sounds like the MC pistons are not returning properly. Can you give it more free play?
1951 1 Ton Completed
I can adjust the push rod to make it shorter. However, the pedal will be down near the toe board when it engages the brake.
