9 members (cmayna, Rusty Rod, TUTS 59, Rusty Heaps, 49choptop, treegrower, Wickedbass, UtahYork, Gray_Ghost), 108 guests, and 1 robot.
Topics128,067
Posts1,055,877
Members48,428
#1123842 09/12/2015 6:05 PM
Anyone have a good method of removing front glass with old dried out, hard, rubber? I am planning on replacing the old rubber on my front windshield and am looking for the best method to remove the window without breaking it as i am planning on reusing it. Rubber is hard and brittle. Truck is a 1957 gmc.
Old Truck addict
1950 chevy 1 ton napco
1956 gmc 1 ton dually napco
1954 chevy 3/4 ton napco
1957 gmc civil defense napco panel
Try to cut away the old seal from the glass side, using a sharp razor-blade.
A sharp utility knife will do it too.
Yep, Utility knife and a sharp blade. Slide in under the rubber, over the glass. Save the paint. It will expose the glass(and the dirt) for easy removal. It also gets the narrow cross section of the rubber. Less cutting that way. Some tape on the handle so the glass is not scratched. That is about it. When the rubber is cut this way the glass comes out easy so be careful.
Steve H
I've always hit it at 90* to the glass. You can feel the blade go under the edge of the glass. No chance of scratching the glass or the paint. Start near the middle of the truck and draw the knife toward you. Sometimes, the harder the rubber, the easier it is to cut.
