| | | Forums66 Topics128,081 Posts1,056,074 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | I need to tweek the T 5 shift lever for a more comfortable shift pattern and was wondering if the lever (not the screw in extension) can be bent in a hyd press without applying heat or breaking. The lever has a nylon part attached to it that I would rather not monkey with. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have heated and bent many. I just keep pouring cold water on the nylon parts.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Taking it apart for a good cleaning and lubrication is easy and the nylon pivot ball can be easily removed. Then heating and bending is worry free. I made a DIY thread showing the basics of taking one apart when I recently customized mine. To disassemble, clean and reassemble, all you need is a grinder and a welder. You'll want to add some grease after you clean the parts. See my shifter thread LINK HERE.
