| | | Forums66 Topics128,052 Posts1,055,725 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2002 Posts: 59 | Do I need to sand down the inside of the fender or can I just wire brush it? And do you prime and paint the same color as the body? Not sure if I want to go that far being I'm not media blasting the whole thing. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It depends on how you want it to look. When I did my Jeep I coated the underside of it with POR-15 and then sprayed on undercoating to deaden the road noise, and it knocked it down some. Some undercoatings can be oversprayed with paint. I'm not sure if our trucks were painted body color or black under there.
