8 members (68ironhead, lumbersawyer, 48jim1ton, Woodcmiami, 3B, J Lucas, Ponchogl, 1 invisible),
97
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 6 New Guy | | New Guy Joined: Sep 2010 Posts: 6 | I was wondering where to find a new flywheel for a 1953 Chevy 3100 1/2 ton 216. My starter and flywheel need to be replaced. I tried a handful of shops looking for a flywheel, but no luck. (Brothers, Classic Ind., Summit Racing, etc.) Any leads would be appreciated. I am in Central CA and was hoping to have it here by Tuesday! Thanks. -BILL | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | Bill Do you really need both? If the teeth are damaged on the flywheel ring gear, you may be able to have a machine shop drive off the existing ring gear and reverse it. New ring gears are available from the Filling Station as are the starter drives. www.fillingstation.com | | | | | Joined: Jun 2011 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2011 Posts: 43 | I have a just surfaced 6 volt 9 bolt pressure plate flywheel off a 235 here in Lodi CA a few hours away $50 if you want to make the drive. I am out of town till monday
Josh | | | | | Joined: Aug 2010 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 38 | I may have one. I would have to dig around. If interested contact me via Email. [email protected] | | | | | Joined: Feb 2012 Posts: 1 New Guy | | New Guy Joined: Feb 2012 Posts: 1 | I needed a new flywheel ring gear for my 1954 GMC water truck 302 engine. We used to get them at the local auto-parts. I was having trouble trying to locate it and one of the vintage parts houses mentioned Stove Bolt. While searching the forums I ran across your post. The Filling Station had the ring gear in stock. I converted the truck to 12 volts decades ago and was concerned I was getting the correct gear as there is a different part listed for 12 volt. The gentleman at The Filling Station knew off the top of his head that the 12 volt ring gear would be used in and after 1955 when the truck became 12 volt standard. The 139 tooth ring gear I had was correct for the application. Thank you for your help. | | |
