7 members (Charles in CA, Otto Skorzeny, Lonnie, 1955 1 Series, dt235sd, Wickedbass, 1 invisible),
125
Mod | | | Forums66 Topics128,081 Posts1,056,076 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 1 New Guy | | New Guy Joined: Sep 2015 Posts: 1 | I have a 1952 3600 3/4 ton. I want to go to front disc brakes with a 5 lug hub. I'm told that a 1973 or newer chev pu front subframe will bolt right in. Is this true? | | | | | Joined: Jan 2011 Posts: 188 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 188 | Not sure if the newer one's will fit, but here's one option you can check out. Here's another. I know there are others, and you might have already looked at these. I'm certain that someone will come by and let you know if it can be done or not though. | | | | | Joined: Dec 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 54 | Short answer, yes it will. Long answer, the stance is too wide for some and you will need 1/2 inch spacers between frame and crossmember because the crossmember is an inch wider than frame. You'll also have to transfer the steering from donor as well and then lower the ride cause it'll be way to high in the front after swap. It would be easier to get a 1/2 ton axle and get the disc brake package that was mentioned earlier.
Tim
