1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 2 Junior Member | | Junior Member Joined: Feb 2005 Posts: 2 | I have a 1964 Stepside. There is rust above the windshield where the cab roof meets the cab. Is there a technique/caulk I need to use to reseal the area where the two pieces are joined?
Thanks for the help. | | | | | Joined: Sep 2004 Posts: 36 New Guy | | New Guy Joined: Sep 2004 Posts: 36 | If there is rust and it's not through the metal, wire wheel it down and use Chassis Saver on it. This will stop further rusting. If it is two seams that meet and need to be sealed, try this, it works great. Seam Sealer
1959 Chevy Apache Stepside 4x4 2009 Chevy Silverado 2500HD Duramax/Allison LB Crew Cab
| | | | | Joined: Feb 2005 Posts: 2 Junior Member | | Junior Member Joined: Feb 2005 Posts: 2 | I have a little more work to do before I use the sealer. I figured there was something out there, but I am a novice. The rust has broken through the metal on the bottom. I will have to do a little repair work before resealing.
It will be a great learning experience for myself and my two boys, 13 and 11.
My father-in-law is a tractor collector and used to be big into antique automobiles (pre 40s), but he is into "preservation, not restoration". I want this truck to be somewhere inbetween.
Thanks for the information. | | | | | Joined: Sep 2004 Posts: 36 New Guy | | New Guy Joined: Sep 2004 Posts: 36 | Sounds like a good test of your fabrication skills. Best case scenario, you find someone who has a parts truck that would be willing to cut a section out for you. Worst case (and not necesarily bad)is you have to fabricate the part yourself. Not sure how big the area is, but it could be small enough to make your own patch or you may end up having to make a patch with some body lines (a little more difficult). You can do it.
