1 members (baldeagle),
37
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | I know this is a dumb question but exactly how do I apply decals after I paint my valve cover & oil filter canister? Do I apply some clear coat after they're on? Thanks
~Denny 1953 Chevy 3100 w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter In the Gallery Forum1998 Chevy Suburban 350 ci awd/4wd | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | First off they are not decals, they're stickers. No need to coat them with anything.
dg
Denny G Sandwich, IL
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Decals, are water mounted. Not to question the sticker explanation above. Just general information for those who have not messed with Decals. Water lets them slide off the paper backing. Water lets you position them on the part you transferred them to. A note of caution, Acrylic Lacquer, can melt them. I an sure that modern solvents will as well. If you want to clear coat for protection, use a clear that can be fogged on and has a short drying time. 3 coats and it should be sealed. Then clear coat and it will come right through like magic. The fogging protects the Decal. Looks bad but the final clear coat will fill in and make it clear and smooth.
Steve H
| | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | Thanks, I haven't actually attempted to use them yet and didn't realize that they're stickers. I remember applying decals from my model car days and they were separated in water. This should be much easier.
~Denny 1953 Chevy 3100 w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter In the Gallery Forum1998 Chevy Suburban 350 ci awd/4wd | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The "decals" that the poster is addressing Steve, I assume are the ones that the vendors sell. They are not water slide decals, they are vinyl stickers.
dg
| | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | If they are stickers try spraying the area with a solution of water with ONE drop of detergent in a spray bottle. It allows you to position the sticker where you want and then use a squeegee (I use a credit card) to smooth it out and remove any air bubbles. It also allows you to remove and reposition it if you need to - although I have never personally needed that function. Ya, right. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | The tip from Peter H has merit. Stickers and position and air bubbles. Good tip. Yes stickers are not decals. But decals are often a new thing for some bigger applications. And not a lot of folks have used them.
Steve H
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The vendor calls them Decals....But we can still persecute the poster.  The English language allows for Vinyl decal or vinyl sticker or Sticker, decal or label. All used interchangeably in the industry. Many companies call them vinyl decals, Classic Parts of America calls the oil filter label: "waterless decal". Bottom line: He wants to know if/how to seal them. I agree they do not need any coating and should not be coated. The instructions do not say to do that.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
