| | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 57 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 57 | I thought that I would add some pics of the new project that I am working on. I originally found this on the H.A.M.B. (Jalopy journal) and thought that I would give it a shot. The intent for my truck is to update the wiring to 12v and update the engine to a newer straight 6 (Chevy 292 cu from a 65 3/4 ton) so why not add a tach at the same time. I will be adding new SW guages with black face and white numbers to replace the original guages, so I thought the speedo and tach should match as well. I went to a local sign shop and had them replicate the speedo face in black and create a tach face for me using the original font. They created decals which go over top of the original speedo face. I will add more pics as the project progress. http://s1075.photobucket.com/user/1...0Tach/image.jpg1.jpg.html?sort=3&o=0[/url]
1966 Chevrolet Caprice 2 Door Hardtop (396 Big Block) 1951 GMC 9434 5 Window (waiting on a 292 transplant) | | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | Nice! Those gauges will look great. | | | | | Joined: Sep 2008 Posts: 57 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 57 | Jim, Thanks. I have added a few more pics. Same link as above. I still have to repaint the centres as I had a small screwdriver slip. Next step is to add the needles, glass and bezels.
Dave
1966 Chevrolet Caprice 2 Door Hardtop (396 Big Block) 1951 GMC 9434 5 Window (waiting on a 292 transplant) | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | It appears that your speedometer shaft is broken
But hard to tell from the pics
You may want to check it out. | | | | | Joined: Sep 2008 Posts: 57 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 57 | Hard to tell, but the shaft is good. I wasn't so lucky with the first speedo that I took apart, snapped the shaft off at the base of the needle. Dave
1966 Chevrolet Caprice 2 Door Hardtop (396 Big Block) 1951 GMC 9434 5 Window (waiting on a 292 transplant) | | | | | Joined: Sep 2008 Posts: 57 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 57 | I added 2 new photos of the speedo and tach, with the needles installed and also a photo with the glass and bezel installed on the tach. Still waiting for the new bezel and gasket to show up for the speedo. For the speedo I have installed a odometer for a 53 Vette which has the black with white numbers, I also have a reproduction odometer with the white with black numbers for the AD trucks, just not sure which way to go for the odometer. For those that are restoring a speedo, Jim Carter sells the reproduction odometer. Once I have the bezel and glass installed, I will post more pics.
Dave
