7 members (Gdads51, Hugh63c10, moparguy, 32Fordpuchoptop, Hanks custodian, ShopRag, Ponchogl), 138 guests, and 2 robots.
Topics128,114
Posts1,056,283
Members48,439
1966 K10. Discovered an anomaly I can't quite explain. When light knob is off fuel indicates a fuel level - full. When light knob is pulled out, fuel indication goes down some (indicated about 3/4 tank) and is steady. When I use the dimmer switch for the instrument gauge lights the fuel indication moves with the dimmer switch. Curious to me at this point. I am sure someone has some idea as to what is occurring?
Hambone
~ HB
1962 Chevrolet C10
1962 Suburban
Hambone, check the easiest thing first. Sounds like your devices are looking for a ground. Run a temporary ground to your Guage cluster and see what happens
~ Jim Schmidt, Bucks County, PA
1953 Chevrolet 3804 1-ton
In the DITY Gallery
HB,
Is this at idle or at road speed?
If it's only happening at idle then it's a matter of Ohm's Law. The voltage is dropping due to the large current flow to the lights, which also changes the current flow on the gas guage. The same thing happens with the blinkers...at idle they flash slow and as soon as the engine speeds up they blink faster.
If it happens at road speed your generator is not charging and Ohm's Law still applies.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Good stuff. Not that I use the lights all that much, I noticed this phenomenon last week and was curious. I will do some more investigating and then add a ground. Can I ground the entire cluster to the dash or am I repairing the ground at each gauge.
Ohms law - I will have to get out my kids physics book and review the theory. That also will be a good father son project.
Thanks gents.
~ HB
1962 Chevrolet C10
1962 Suburban
Ham, just get a long heavy alligator jumper. Attach one end to a solid body ground and the other to to Guage cluster. See what happens. If nothing we will look at it in Winchester
In the DITY Gallery
The fuel gauge is sensitive to voltage fluctuations. Fancy way to say grounds matter. The above suggestions are good ones. If a ground wire fixes the issue, the problem is solved. Enjoy
Steve H
I checked some more stuff with this situation. Occurs at all RPMs. Fuel gauge bounces with blinkers as well. Sounds like a new ground is required. I will head in that direction.
~ HB
1962 Chevrolet C10
1962 Suburban
