7 members (Otto Skorzeny, Phak1, TUTS 59, Hotrod Lincoln, Gray_Ghost, Crimson48, 1 invisible), 134 guests, and 2 robots.
Topics128,080
Posts1,056,063
Members48,433
Fixing to pull the radiator today on my 61 Apache. Don't know if I'll get it repaired or replaced. If replaced, does anyone have any recommendations on suppliers? I have read that the after market radiators sometimes don't bolt right up without bracket modification. Would like that not to happen.
Thanks.
U
U Offline
Go get the one you have checked out first. Not worth worrying about supplier/replacement/mounting/etc (like I did) until you know if you need a new one or not. Local radiator shops can clean, pressure check, and make any repairs. $40-$60 range in my experience to have a radiator cleaned out & O/A weld repaired.
Obviously, the ones I took in for clean, test, & repair looked fine & didn't have bullet holes or rust holes in them.
Brad
edit- but there are plenty of folks here who have experience with aftermarket sources;
Also-if your radiator needs to be re-cored it will be a lot more expensive than the $40-$60 I mention
Wrench Fetcher, PhD
Great advice. Just got it out of the truck and taking it to the repair shop tomorrow. No bullet holes, so I'll hope for the best.
Thanks for the response.
Crusing in the Passing Lane
I think Walker in the southeast somewhere makes new Brass ones, check their adds in magazines.
