1 members (Hush), 73 guests, and 2 robots.
Topics128,211
Posts1,057,475
Members48,473
hi.
looking for advice on how to remove the grille - specifically, the bottom bolts.
I am trying to remove the grill for sanding and painting.
I removed the top cross member (right name for it?) that has the latch for the hood.
I was then able to remove the top 6 bolts that hold the top of the grille in place.
so far, so good.
but, there appears to be 4 bolts coming up into the bottom of the grille, and I see no way to get a wrench of any kind on those bolts.
anyone figured out how to get to them?
Thanks in advance
Gene
Hello, Gene,
1/2 ton
1955 1st series or 2nd series?
Hello, Gebe,
1/2 ton
good question. sorry. 2nd series.
U
U Offline
Lemme check my notes & pictures...
Ok, is the radiator support & radiator still installed?
It looks like the grill has six (6) attachment points top & six attachment points on bottom. The outermost are welded nuts; two on top two on bottom. The lower grill assembly "valance" (horizontal under the grill) is attached on the outside to the left & right fenders.
I removed the lower grill "valance" attaching bolts & pulled it & the grill out together. The pictures I have won't help you.
Brad
Wrench Fetcher, PhD
Brad
I got it out! Thanks for the pointers.
attaching some pics in case someone else ever wonders how to get it out (like me 2 years from now....).
here it is all in place (kind of, just laying in there for the pic)
all in place
here it is with top cross member/ hood latch removed:
top piece removed
here it is with small cross support (red in previous pic), grille and bottom valance removed:
all removed
here are the parts removed:
parts removed
top cross member top bolt holes and bolts:
top cross member holes and bolts
small cross support holes
bottom valance holes - two to each fendor (get at it from inside the fender by the wheel) and one to bottom radiator support (get at it from underneath)
U
U Offline
Good documentation to keep- thanks for posting it.
Go ahead & write down what size & thread capscrews/bolts came out of each hole, maybe Ziploc store them. Even though it's documented many places, I found it was easier to do this when the parts were fresh in my mind.
Brad
Wrench Fetcher, PhD
