Lemme check my notes & pictures...
Ok, is the radiator support & radiator still installed?
It looks like the grill has six (6) attachment points top & six attachment points on bottom. The outermost are welded nuts; two on top two on bottom. The lower grill assembly "valance" (horizontal under the grill) is attached on the outside to the left & right fenders.
I removed the lower grill "valance" attaching bolts & pulled it & the grill out together. The pictures I have won't help you.
Brad
I got it out! Thanks for the pointers.
attaching some pics in case someone else ever wonders how to get it out (like me 2 years from now....).
here it is all in place (kind of, just laying in there for the pic)
all in place here it is with top cross member/ hood latch removed:
top piece removed here it is with small cross support (red in previous pic), grille and bottom valance removed:
all removed here are the parts removed:
parts removed top cross member top bolt holes and bolts:
top cross member holes and bolts small cross support holes
small cross support holes bottom valance holes - two to each fendor (get at it from inside the fender by the wheel) and one to bottom radiator support (get at it from underneath)
