| | | Forums66 Topics128,052 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 41 | If I was wanting to replace all nuts and bolts on front end of my 57 1/2 ton where would I find such kits? Inner fender bolts, fender bolts, etc. | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I'm sure somewhere sells the kits - why not make your own "kit" up? Take each bolt off & measure it with a caliper, noting their thread pattern, & also the dimensions of any washers. I put these in a Ziploc bag, labeled the outside of the bag, & then counted the total number I needed by going over the truck. I multiplied that number by two for extras.
Inner fenders are attached to fenders with 5/16"-18 cap screws; same for the radiator support to fender mounting points. 1/2", 3/4", & 7/8" lengths will probably do the trick all the way around. I am unsure what size I used to attach the fender braces.
Replacing bolts is a dangerous undertaking; it can lead to replacing a lot more parts. Lock all of your sanding, grinding & wire wheel tools up. Focus only on the bolts in a one-for-one exchange & you'll be done in no-time. You will probably need to have a tap & t-handle handy, a torch... BFH...penetrant...wasp spray... But, I have no idea what the condition of your truck is.
Brad
Wrench Fetcher, PhD | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | stainless kits available at Jim Carter or American Classic among others Bill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Welcome back Bill!! I was afraid you'd written us off.
