9 members (TUTS 59, 1955 1 Series, NJC, WICruiser, 51sub, greenie-reddy, Peggy M, Tronman, Gray_Ghost), 122 guests, and 2 robots.
Topics128,265
Posts1,058,360
Members48,485
#1122141 09/02/2015 2:38 AM
The '53 replacemet engine I put in my '46 2-ton came with a governor under the carburetor. It seems to be in good shape, it's clean on the inside and I could work the throttle plate in it by hand. There appears to be a connection point on the outside that a small tube would connect to. Where would the other end of such a tube go? Does the governor sense vacuum or pressure of some sort?
Since I actually use the truck I would like to protect the engine from over-revving.
Governors are usually controlled by a special distributor with a speed-sensing device below the breaker plate that closes off the governor throttle plate with vacuum as a preset speed is reached. Unless you also have the correct distributor, you've only got half the system.
Ed,
Does your governor look like this one? (48-52, and maybe 1953).
Most likely, your carburetor is like the one at the link above. Here is the 1954 governor - it looks like the earlier one.
The operation of that governor is described in those shop manuals. I do not see a mention of a speed-sensing device in the distributor, but I did not study the Shop Manuals very carefully. It looks to me like the adjustments are made in the governor assembly. The 47-55 GM governors that I have taken off of trucks up to 2-tons are as shown in those Shop Manuals (270 amd 261 engines).
Are you missing the adjusting screw/cap and/or associated parts?
Do you have the carburetor that came with the engine and governor?
I'm pretty sure the earlier one barrel governors were mechanical. One of Tim's links has a good write up on the operational theory. I know the later four barrel governors were speed sensing off of the distributor tach signal.
SimS
Yes, that link explains the operation pretty well. The 503 GMC I'm working on now has a distributor-controlled governor on a big 2-barrel Holley carb.
Yes, tclederman, that looks like it. There is no cap, which is why I thought maybe it hooked up to something else. How hard are parts of this to come by? While it would be nice to have working, I don't have a lot of $ to spend on it.
