| | | Forums66 Topics128,040 Posts1,055,474 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2002 Posts: 62 | I've started restoring the radio out of my '53 3100. I want to take out the guts then media blast and paint the case. My question is, what color was the original case? I can't tell if it's a very light gray paint or if it's more of a clear coat.
What type of paint should I use to get back to an original finish? | | | | | Joined: Nov 2003 Posts: 86 Member | | Member Joined: Nov 2003 Posts: 86 | A very light gray would describe the color of the radio in my 53. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Most I have seen are a " hammertone grey " | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Is the hammertone similar to the deluxe heater finish, MT? If so, you can get a pretty good match with the hammertone spray paint sold by Rustoleum.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Nov 2003 Posts: 86 Member | | Member Joined: Nov 2003 Posts: 86 | 4onthefloor, the radio color and the header color aren't even close. At least on my machine. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | 4 on the floor... The Fresh air heater hammertone grey is almost identical to the radio color. You can get this paint on the top shelf of any Home Depot. | | |
