| | | Forums66 Topics128,266 Posts1,058,367 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | Will a fuel pump off a '46 235 fit on a '53? I know the gasket to the block is the same and the plumbing is the same, but is there an internal difference that would keep it from working? The pump on my '53 replacement engine just let loose (fuel spraying out) and I have a good pump on my '46 block that could get me out of trouble if it will fit. Thanks | | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | I took the pump off the '46 and it is a direct replacement. The '53 had the glass bowl on top and the '46 doesn't. It seems to be the only difference. | | |
