6 members (55shaker, Wickedbass, FAST55, rfs56trk, Hotrod Lincoln, Hanks custodian), 57 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
#1121635 08/30/2015 2:25 AM
I'd like to clean up & paint the engine in my '53 3100 but I can't pull it to do so. My plan is to have the valve cover, oil filter cannister, air filter assbly & horns blasted & I'll spray them. Is it impossible for me to paint the head & block without pulling the engine? I plan to clean them first by powerwashing. Any advice/tips are appreciated.Thanks
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
A steam jenny would work much better than a standard pressure washer. Cold water tends to just move the greasy oil around and not remove it. Pre-treatment with degreaser might work with a standard pressure washer.
Carl
i painted mine in the chasis. Later, i pulled it when i realized the rubber in motor mounts needed to be replaced. needless to say, she got repainted.
Chris
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=819665
Quote from above thread
Originally Posted by LonnieC
I finished painting my engine and engine bay with the engine in the truck. Not a speedy task. Seemed like I would spend a couple of hours masking, then paint for a few minutes. I removed most of the parts to clean and paint off of the engine. Didn't remove the carb or lines because I didn't want to create leaks. Thanks to DavidF for the aluminium foil masking tip in another thread.
I used almost three rattle cans and a quarter of a pint of brush-on of Filling Station engine paint. I found some areas on the engine that I missed. Can't touch them up now - already getting oil on them from oozing valve cover etc.
I thought that I had the job planned out pretty well, but I ended up masking and painting multiple times in the same areas. Suggest painting the frame areas first, then the engine, and the inner fenders last. (I painted the engine first.)
Used Calyx on the rusty exhaust manifold. Looks great and was simple to use. Also used it on accelerator, brake, and clutch springs.
Here are the paints that I used:
ITEM / / BRAND / / PART # / / DESCRIPTION / / SHEEN / COLOR (Notes)
Engine / / Filling Station / / FS-359 & FS-119P / / Engine Enamel / / Dark Gray
Generator / / Dupli-Color / / DE1635 / / Engine Enamel / / Ford Semi Gloss Black
Starter / / Dupli-Color / / DE1635 / / Engine Enamel / / Ford Semi Gloss Black
Generator Brackets / / Dupli-Color / / DE1635 / / Engine Enamel / / Ford Semi Gloss Black
Starter Rods / / Dupli-Color / / DE1635 / / Engine Enamel / / Ford Semi Gloss Black
Heater Hose Bracket / / Rustoleum / / 7798830 / / Protective Enamel / / Semi Gloss Black
Frame / / Rustoleum / / 7777830 & 7777502 / / Protective Enamel / / Satin Black
Steering Box / / Dupli-Color / / DE1651 / / Engine Enamel / / Cast Coat Iron
Inner Fenders / / Rustoleum / / 7777830 / / Protective Enamel / / Satin Black
Headlight Buckets / / Rustoleum / / 209584 / / Automotive Aerosol / / Semi-Gloss Black
Headlight Inner Bucket / / a coat of Rustolium aluminum and a mist of Rustoleum Galvanized
Fan / / Rustoleum / / 209584 / / Automotive Aerosol / / Semi-Gloss Black
Air Cleaner / / Rustoleum / / 209584 / / Automotive Aerosol / / Semi-Gloss Black
Coil Bracket / / Rustoleum / / 257884 / / Automotive Enamel / / Gloss Clear
Coil / / Dupli-Color / / DE1635 / / Engine Enamel / / Ford Semi Gloss Black
Radiator / / Rustoleum / / 7798830 / / Protective Enamel / / Semi Gloss Black (Similar to Auto Semi, I had more Protect available)
Steering Column / / Dupli-Color / / DE1634 / / Engine Enamel / / GM/CHRY Low Gloss Black Flat, slight grey tint - similar to column inside cab)
Pic 1
Pic 2
Pic 3
Pic 4
Pic 5
Pic 6
I posted the results of painting the frame and inner fenders in another thread.
Thanks for your help in pointing me in the right direction.
Like LonnieC, I did an engine repaint recently in situ. Hours of tedious masking and covering for a few minutes of spraying followed by more of the same. My engine was fairly clean so I only had to do a good clean up with solvent and rags to remove any oily residue. Remove everything you can like, breather, oil filter, distributer cover, plugs and wiring and starter the more the better and paint separately. A few areas under the manifold were better reached with a small artists brush, and I still have some areas to get to later. I used Dupli-Color hi temp Cast Coat Iron Gray for the block, and POR 15 gray for the manifold. I tried the Dupli-Color Ford Gray DE1611, but it is too light and blue for my taste. I found the Rust-Oleum Painter’s Touch to be very good for blacks.
http://i1291.photobucket.com/albums/b542/RdLessTaken/IMG_9186.2sm_zpse3t6bmj9.jpg
This post is timely because I have the same situation where I do not need to remove the engine. But I will be removing the front fenders to install new welt and that will help when I paint the engine area. Both examples look really good. Steve
Thanks for the tips & the pics. What beautiful work! I hope I can do half as well
~Denny
1953 Chevy 3100
Hey Gus,
I haven't been on the board for quite a while. Thanks for reviving my old thread about engine painting. The engine still looks pretty good. I recently painted the engine in my '55 MG TF-1500 without removing it from the car. The head and exhaust / intake were off of the MG so it was pretty easy.
A couple of things to add:
1) I cleaned the 3104 engine and the MG engine with my $9.00 Harbor Freight Engine Cleaning Gun. Use Gunk and kerosene, or straight kerosene. Then Dawn and hot water through the HF gun, and rinse with hot water through the gun. Blow dry. The gun uses very little liquid - perhaps less than a pint. I find a lot of uses for it. A toilet brush works well to scrub hard to reach places.
2) High quality paint will flow smoothly on cast iron surfaces with a brush. I used Filling Station engine paint on the truck and Bill Hirsch engine paint on the MG. Both were superb. Like RdsLessTaken, I found that artist's brushes were helpful.
3) An air brush will get paint into locations that may be difficult with a gun or brush. I used brush, air brush, detail gun, HVLP gun, and rattle can - depending on the location.
4) Spend extra time on the valve cover and push rod cover. Prime and wet sand until mirror smooth, then spray. Do the same when painting the air cleaner black and other stamped parts. At least feather the chips on the inner fenders before painting black.
5) Finish with period correct decals.
- Lonnie
- Lonnie
My '54 3104
