| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 75 'Bolter | | 'Bolter Joined: May 2014 Posts: 75 | Would a three speed transmission from a 1947 truck fit my 1951? Mine is a 3600 model with the original 3 speed. I don't know what model the 47 came from. Both have the 216. Brad. | | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | Hello Brad, I am not going to be any help but I noticed in the parts book that there are two different part numbers for 41-47 3 speed transmissions and 48-53 three speed transmissions under the "commerical" heading. In the notes for the "commercial" 3 speed transmission it says something about a 3/4 ton truck. Hard telling what the difference is in part numbers. Maybe something simple to swap but maybe a completely different design. Hopefully someone with some direct knowledge will chime in http://chevy.oldcarmanualproject.com/parts/1929_54/251.htm | | | | | Joined: Dec 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 54 | I don't know about the trans themselves, but I do know the out put yokes are different sizes 1/2 to 3/4 in the AD truck. | | |
