10 members (Samantha, Bill Hanlon, 55shaker, 1955 1 Series, cmayna, Otto Skorzeny, Stelonlevo, JW51, treegrower, 1 invisible), 133 guests, and 2 robots.
Topics128,071
Posts1,055,901
Members48,429
Hi,
Was working on my dads 1951 half ton truck. Truck runs really good (especially after new wires and correct R45 plugs). Pulled the valve cover because some time in the past it was put on with RTV and it looked bad.
It was pretty gunked up, but not that bad. I cleaning it up when I noticed this pushrod. It is rubbing the side of the hole in the head and not centered on the valve stem. Everything else is good. Is there some sort of spacer I can put on the rocker shaft?
http://i.imgur.com/prhJ1hc.jpg
This is me holding the rocker centered on the valve stem and centered in the hole:
http://i.imgur.com/nGCozYe.jpg
Thanks for the help
1951 1/2 Ton 216ci 4spd
1955 3/4 Ton NAPCO 235ci 4spd
1959 1/2 Ton stepside 235ci 4spd
Congrats Denny post number 10,000 !!!!!
1947 GMC Truck 5 window, Long Bed
2008 Corvette Roadster
2008 Harley Davidson FXDL
2011 F150 Ecoboost 4X4
2015 Subaru Outback AWD
"only the strong survive"
I would say it is the wrong rocker or the wrong support.
1951 1 Ton Completed
looking at the colour alone it looks to have been swapped out at some point.
Ok that makes sense, so the rockers are cast differently? The rod adjuster hold is basically cast to far over to one side for this rocker location.
Just searched and it seems all pre 1952 rockers are the same, and then there are 2 generations of 235 arms. Seems that the other rockers have a more symmetrical casting.
who can I contact for a single used arm to swap on? Seems to be only whole sets on ebay. Thanks!
Hard to tell with out seeing the whole picture but it does
look like your missing the spring and washer or someone at
some time got a rocker with the wrong throw in there.
Take a look at this and see if it matches your layout:
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0611.htm
DG
GREAT!!!!! Appears to be intake valve for cylinder number 2? The diagram shows what appears to be the back half of the rocker assembly, but id assume its mirrored on the other side. Third rocker in from the front.
The spring and washer are out of the picture to the left more next to the oil tube
Hey Bruce, that count only means I spread lots of manure
around over the past decade, just ask Hotrod Jerry, I
believer he thinks that's all I'm capable of producing!
dg
He just does that to boost his post count. smile
This 4 part video might help.
Part 1
Part 2
Part 3
Part 4
1929 - 1954 Master Parts and Accessories Catalog
Group Number 0.333 ARM, Valve Rocker
To find what cast number is on rocker arm.
Denny, even though cattle hauling is one form of trucking I never did, I recognize the talent of a fellow bull shipper! It's all good!
Part 1
Part 2
Part 3
Part 4
Hi thanks alot for the help. Did not realize the rocker assembly was in 2 pieces, and this will be a good time to clean the whole assembly.
Pretty sure its an intake rocker: http://1954advance-design.com/Web%20images/1958-60-rocker-oil/1958-1.jpg
Then according to this the number 2 cylinder intake valve requires a LH Rocker cast #5, part number 839563.
I guess the search begins. Should I post a wanted ad looking for a #5 rocker for a 216 engine? Or should I just buy a complete rocker assembly?
Thanks all!
-Funny, when I search that part number it is giving me a 216 flywheel...
' Offline
Denny Graham says, The correct rocker is in GP. 0.333, PN. 839464, cast 839465 RH Inlet number three cylinder. For 50-53 all w/216.
Actually the casting # is 839466.
Photo of GM # 839464
photobucket
http://i669.photobucket.com/albums/vv57/glp0329/839464/Right_Inlet_GM__839464__zpsh1kqyh3g.jpg
Dan's Obsolete
in
Chinook, Montana
phone: 406-357-2615
has ( 2 ) GM NOS Rocker Arms - GM part # 839464
Chicago Auto Parts
in
Saint Anne, Ill.
phone: 815 - 614 - 3122
has ( 1 ) GM NOS Rocker Arm - GM part # 839464
1954 3600
Now cruising in
The Passing Lane
photobucket
Dan's Obsolete
in
Chinook, Montana
phone: 406-357-2615
Chicago Auto Parts
in
Saint Anne, Ill.
Wow this is great!! Would much rather just call up and order one (then wait around on a classified ad), but I didnt think that was possible.
Just to be clear, I need the rocker arm for the #2 cylinder, third pushrod in from the front. Just want to be sure there was no confusion because you wrote 'number three cylinder'.
Opps, that's my mistake, had my focus on the center of
the assembly.
I'll edit my replies, no need to add any more confusion than
there is normally created in these threads. As to what's left
behind by the quodophiles, well, I can't correct that.
Sorry I miss read you picture, that's what happens when you
let a dyslexic into your discussion.
dg
Denny G
Sandwich, IL
the assembly.
dg
Thanks so much, I will call dans obsolete and ask for GM# 839464. I dont know enough about this stuff to figure this all out on my own, so I really appreciate it.
Here is the pushrod cover I repainted gray, decided to leave the valve cover and filter cover the blue it was when we bought it 13 plus years ago. Added the thriftmaster sticker too!
http://i.imgur.com/5ibXQLr.jpg
Exactly as I posted...the reason I've bailed on this thread is
it's gotten entirely to confusing.
If it's the intake of No.2 than it's a Left hand intake rocker.
Look in the shop manual and parts book. A Left hand intake
rocker for a 50-53 216 is pn. 839463 and should have a
839465 casting number.
dg
Denny G
Sandwich, IL
' Offline
The Left - Intake Rocker Arm is GM # 0.333 - GM # 839463
with a casting # of: 839465
Last # in the casting # is the " LARGE 5 "
photo @ photobucket
http://i669.photobucket.com/albums/..._Intake_Casting__839465__zpsabfom9f7.jpg
Dan's Obsolete
in
Chinook, Montana
has ( 7 ) - GM # 839463
phone: 406-357-2615
1954 3600
Now cruising in
The Passing Lane
I changed that last number George, thanks, the wife's been after
me to get new glasses, think I'd better take her advice or
start wearing my OptiVisor at the confuser.
dg
Denny G
Sandwich, IL
photo @ photobucket
Dan's Obsolete
in
Chinook, Montana
phone: 406-357-2615
THANK YOU
yes this thread did get confusing! Appreciate the effort, cant wait to get the 51 back on the road!
