2 members (68ironhead, Gdads51), 59 guests, and 1 robot.
Topics128,049
Posts1,055,691
#1120816 08/25/2015 1:18 PM
Just read the most recent post on a cracked head. I have heard of heads being repaired. What is the possibility and experience out there about doing this?
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
MikeE #1120888 08/25/2015 10:24 PM
The head on my Ford 800 (4 cylinder) tractor was cracked in 3 places when I took everything to the machine shop in Columbia, Mississippi. The shop welded it up and I went right on with the engine rebuild and 4 years later all is fine. They told me at the machine shop (a really top-notch shop BTW) that cracked heads can sometimes be repaired and their estimate was that mine fell in that category. So far, so good.
lane
sweetpealane
MikeE #1120893 08/25/2015 10:36 PM
Many will tell you that the 235 head cannot be repaired successfully. I went through three before finding one that was good.
Mark
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
MikeE #1120981 08/26/2015 4:04 PM
Check out this website for cast iron repair.
http://www.locknstitch.com/index.html
1946 1/2-Ton Chevy
MikeE #1121013 08/26/2015 8:13 PM
U
U Offline
Very interesting to read these procedures : from the link above posted by JiMerit.
Brad
Wrench Fetcher, PhD
MikeE #1121029 08/26/2015 9:59 PM
I liked the article too. Question is how much does all this cost and is it worth it. I haven't found a place locally yet and shipping is expensive.
1946 1-ton Panel
MikeE #1121166 08/27/2015 3:23 PM
I do know cast iron heads can be welded, however it is an art, and finding an artist can be difficult. I am fortunate in that there is one fella here in Seattle that is one of the premier cast iron welders. Look up Hill head and machine. They specialize in heads only, (well they did have a couple of flathead ford blocks in there, but even they like to have their fun) The fella running it is second generation, and is a consummate professional.
MikeE #1122992 09/07/2015 7:01 PM
MikeE, mine was cracked between the #5 intake and exhaust ports. I sent mine to RJ's Machine and Welding in Chapin Il. They flame weld cast iron and slow cool it over long hours, that's the secret. If cast iron cools too quickly it will crack at the weld point. They have been around for many decades. When I had mine done a few years back they charged a flat $200.00 for an automotive head and they bore and fitted hardened seats included. They even put new valve guide seals on. The shipping down and back was about as much as the repair job for me. I don't know how far north of the border you are from me for shipping. Their number is (217) 472-5121
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
MikeE #1123033 09/08/2015 12:58 AM
Thanks everyone. bzt, I am in Green Bay, but I will investigate a side trip there.
1946 1-ton Panel
