| | | Forums66 Topics128,049 Posts1,055,695 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Just read the most recent post on a cracked head. I have heard of heads being repaired. What is the possibility and experience out there about doing this?
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Oct 2013 Posts: 97 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 97 | The head on my Ford 800 (4 cylinder) tractor was cracked in 3 places when I took everything to the machine shop in Columbia, Mississippi. The shop welded it up and I went right on with the engine rebuild and 4 years later all is fine. They told me at the machine shop (a really top-notch shop BTW) that cracked heads can sometimes be repaired and their estimate was that mine fell in that category. So far, so good.
lane
sweetpealane
| | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | Many will tell you that the 235 head cannot be repaired successfully. I went through three before finding one that was good.
Mark | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Very interesting to read these procedures : from the link above posted by JiMerit. Brad Wrench Fetcher, PhD | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I liked the article too. Question is how much does all this cost and is it worth it. I haven't found a place locally yet and shipping is expensive.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I do know cast iron heads can be welded, however it is an art, and finding an artist can be difficult. I am fortunate in that there is one fella here in Seattle that is one of the premier cast iron welders. Look up Hill head and machine. They specialize in heads only, (well they did have a couple of flathead ford blocks in there, but even they like to have their fun) The fella running it is second generation, and is a consummate professional. | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | MikeE, mine was cracked between the #5 intake and exhaust ports. I sent mine to RJ's Machine and Welding in Chapin Il. They flame weld cast iron and slow cool it over long hours, that's the secret. If cast iron cools too quickly it will crack at the weld point. They have been around for many decades. When I had mine done a few years back they charged a flat $200.00 for an automotive head and they bore and fitted hardened seats included. They even put new valve guide seals on. The shipping down and back was about as much as the repair job for me. I don't know how far north of the border you are from me for shipping. Their number is (217) 472-5121
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Thanks everyone. bzt, I am in Green Bay, but I will investigate a side trip there.
