3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#112095 08/07/2002 2:48 AM
hello all. i was spray-painting a part gloss black rustoleum and those little "fish eyes" appeared! so i let it dry a couple of days, gave it a light sand, cleaned it, then sprayed again. same results. :mad: ive spray-painted alot of my parts and never had this problem before. is the paint bad? what should i do? does the part need to be stripped down completely and redone? thanks!!
1948 GMC 250 Series Flatbed
#112096 08/07/2002 3:09 AM
The part itself or the paint is contaminated.
Silicone is usually the culprit.
Wiping a mixing stick with a rag that was used for applying Armor All will ruin your paint. Even half a day after Armor All, silicone spray or oil is vaporized, residual will trickle down on your work surface. Air powered tools (impact wrenches, etc) actually vaporize lubricating oil as they are used.
Since you already have paint on the part and holes (voids) have formed, you'll have no choice than to sand smooth.
Are you using a mild cleaning solvent BEFORE spray painting? Not thinner or reducer, they will soften the base.
whizzerick
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
http://www.whizzerick.com
