4 members (DaveV, Paul_WNC, Rusty Heaps, Otto Skorzeny), 76 guests, and 0 robots.
Topics128,050
Posts1,055,646
#1120842 08/25/2015 4:10 PM
I know I saw it in the forum someplace, but can not find it.......I would like to remove my steering column so that I can do some work on the dash. What would be the best and easiest way to do this? It is on a 1940 1.5 ton......thanks for the knowledge!
BJ
BJ
'Keep on Truckin'
1940 1.5 ton dump
The column is two piece, an outer mast jacket, and the actual steering shaft. The jacket is held on the steering box with a clamp. Neither will come out while the gear box is bolted to the frame. Removing the pitman arm and dropping the box out the bottom of the frame is the only way to get it out of your way. The steering shaft only comes out through the gear box, the jacket tube will slide off the shaft and gear box, but only after removal from the truck.
Joe
Thank you Joe, will give it a go.....hopefully I won't find something to fix there too!....lol
BJ
'Keep on Truckin'
1940 1.5 ton dump
