| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2015 Posts: 23 | I know I saw it in the forum someplace, but can not find it.......I would like to remove my steering column so that I can do some work on the dash. What would be the best and easiest way to do this? It is on a 1940 1.5 ton......thanks for the knowledge! BJ
BJ 'Keep on Truckin' 1940 1.5 ton dump
| | | | | Joined: Feb 2000 Posts: 5,199 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,199 | The column is two piece, an outer mast jacket, and the actual steering shaft. The jacket is held on the steering box with a clamp. Neither will come out while the gear box is bolted to the frame. Removing the pitman arm and dropping the box out the bottom of the frame is the only way to get it out of your way. The steering shaft only comes out through the gear box, the jacket tube will slide off the shaft and gear box, but only after removal from the truck.
Joe | | | | | Joined: Aug 2015 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2015 Posts: 23 | Thank you Joe, will give it a go.....hopefully I won't find something to fix there too!....lol
