7 members (Bill Hanlon, Tom McGrath, Rich'sToys, Jman, Robert Crandall, Steelonsteel, Wally / Montana), 85 guests, and 4 robots.
Topics128,035
Posts1,055,556
#1120404 08/22/2015 11:05 PM
Would a three speed transmission from a 1947 truck fit my 1951? mine is a 3600 model and I don't know what model the 47 came from. Both have the 216.
Brad.
I'm pretty sure the bolt pattern on the bellhousing is different.
Bill Burmeister
The torque tube parts are different from a 3100 vs a 3600.
I think the length of the transmissions are also different 47 vs 51?
Ok if the 47 trans wont bolt up directly, what about the internal "guts" of the trans, were they basically the same?
I have problems internally with the 3 speed on my 51 3600 and I can get two used 47 3 speeds, I don't what condition they are in, and was hoping I could just swap out the parts I need and get the 51 speed working properly.
I don't know exactly what is wrong with the 51 3 speed, I just found these 2 47 3 speeds for a great price.
Brad.
I just realized I posted this in the ENGINE section of the forum...should I post this in the DRIVELINE section instead?
Brad
A lot but not all of the parts will interchange.
Here are two links to my blog on transmission interchange.
Transmission bolt patterns.
Transmission lengths.
My Blog
Crusing in the Passing Lane
If the '47 trans is a 420,then it will fit if the drive lines are the same, if it is an earlier trans(for got the MN) then no,bolt pattern is different. A 465 would also fit.
SM420 did not start until 1948.
My Blog
I'm going to move my post to the driveline forum.
Thanks everyone.
Brad.
