1 members (baldeagle), 91 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#112056 01/10/2002 4:06 AM
My bed had minor pitting and I filled them with primer. would the heat from welding damage the primer when I reattach my angle strips. If I can't do this would pop riveting be a practicle method.
Thanks Brady
#112057 01/10/2002 8:21 AM
Go ahead and weld them. If you use a mig welder and have new angle strips, plug weld them from the outside of the bed. This way you won't have to do any grinding or sanding on the strips themself. You will have to grind a small amount in front and rear of the fenders. Don't worry about what is behind the fenders, you can't see them anyway. With pop rivits. they would show and might not look quit right. It sound like you are doing all the right steps, don't stop now. Also, the angle strips are what hold the bed sides up. Everything starts from them. Pop rivits may work loose.
Make sure you get the angles in the right place and straight. I got mine a little bowed in the middle. No one can see this but me, its just one of them thinks that make you mad. Joe
#112058 01/10/2002 3:33 PM
It's simple, don't fill any of the pits that are going to be hidden with the strips anyway. There won't be any primer there to burn.
Be sure you do protect behind the strips though. You need to etch prime or epoxy or something behind the strips (maybe Ras O Nil)and then clamp the strips in place and drill the hold to plug. Only drill through the bed and the tip of the drill hitting the strip will be your bare metal for welding.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
