2 members (WICruiser, TexasA&M48Truck), 146 guests, and 3 robots.
Topics128,081
Posts1,055,959
Members48,430
Hi Stovebolters....
I have been trying to make up a pair of running 1 ton running boards for my 9 foot 1 ton pickup truck...trying to cobb a pair of normal size running boards to a set of dump truck (really short) running boards...I have cut and chopped myself into a corner....cant seem to be able to get anything to line up.....
has anybody cobbed up a pair of 9 foot bed long bed running boards before????
I am about to leave them off...it isn't really worth this much thought to get them to mount onto the truck...Maybe does anybody have any pictures of the super long running boards that I can reference?? (mounted on the truck)...
Any insight would be great...
MikeC
1951 Chevy 3800 1-Ton
Howard Knapp
I bought a pair of running boards someone repaired. Patched in panels and it was done poorly. After doing all the straighting I could I was able to get the ribs to look very good by cutting a body filler applicator to match the rib and valley. I then did the filler. There was a bit of filing and a few finish coats but it came out very nice. I spent a month on just the pair.there are some before photos in photobucket. I have finished photos I can send you. I sold them and the person who bought them was happy. There is hope!
Hi GWWirth
I was a cobbing machine tonight...I got the passenger side to work for me...it came to me in a dream how to do it...
here is what it looks like now...
thanks for the encouragement tho...
MikeC
Howard Knapp
I noticed you hadn't incorporate the third/rear support bracket. Were you going to fit that next? You'll want the step to handle your weight.
Dave Baird
1951 Chevy 3803
Great. I solve many things with a bit of sleep. Looks good
Hi Dave51Chev
Yuppers I am waiting for them to show up from Florida...I bought a set (used and abused) of 6 for $75.00 shipped to me door..I might have to add a couple extra just for some extra support...
never drove a truck with running boards before...this should be an experience for sure...never owned a truck this big either....hoping it will not scare me when driving time comes around...still cant wait to get it done...
MikeC
Howard Knapp
while the 1 ton may be long the AD models are not wide at all.
I started driving mine on my 17th birthday and found it to be very maneuverable, it'll fit easily where modern full size trucks won't, and good visibility.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Stovebolt Photo Moderator
I have a friend who built inside steps on a 60 ford behind the door. He ribbed them by welding a thin (1/8" high, 1" wide) piece to the top and rounding the exposed edges. You can't tell the difference between the raised thin piece vs. the passenger side with a depressed edge. Cool idea. I can send a photo if you're interested.
1947 - 3800 dually known as "Deadwrench"
Link to a few photos
In this world there are givers and takers. The takers eat well, the givers sleep well.
I got my boards and brackets from a one ton panel (3805). Learned a lot from that donor. Curiously, my 3803 (cab & chassis) frame already had the bracket holes. Bolted right up.
Dave Baird
1951 Chevy 3803
So I am still cuttin and fittin
mocked up and ready for welding
close up before welding
I learned that the younger folks call what I do "grelding"...I call it grinding and welding...or cobbing stuff together...
I don't have the splash aprons figured out yet but the this weekend we will finish bolting my new 1 ton running boards on it. All the brackets are welded to the frame...holes are all drilled for the running boards...I am short 8 5/16" x 2" long bolts and we will be one less project away from getting this thing out of the garage...
cant wait
Howard Knapp
rear running board bracket
this overall shot shows both "new" running board brackets
Howard Knapp
Moderated by  Dusty53
